Use this procedure to view NEAP client MAC information on a port.
  1. In the navigation pane, expand Configuration --> Security --> Data Path.
  2. Select 802.1X – EAPOL.
  3. Select NEAP Radius tab.
NEAP Radius Field Descriptions
The following table describes values on the NEAP Radius tab.
Name
Description
MacPort
Indicates the port number associated with this port.
MacAddr
Indicates the MAC address of the client.
MacStatus
Indicates the authentication status of the NEAP host that is authenticated using the RADIUS server.
VlanId
Indicates the VLAN assigned to the client.
MacClear
Clears the non EAP MAC entry associated with a specific index.
MacPriority
Indicates the priority associated with this Non-EAP client MAC. This priority could be the Radius assigned priority or the port QOS level.
SwUniBindings
Indicates the VLAN and I-SID bindings. VLAN is represented with 2 bytes and I-SID is represented with 4 bytes. The output is a continuous hexadecimal representation of the VLAN that is followed by the corresponding I-SID.
IsidSource
Indicates the source of the I-SID value. An I-SID value is generated in one of the following ways:
  • radius—Indicates that that I-SID value is learned from the RADIUS server.
  • autoconfig—Indicates that I-SID value is calculated by using the auto-isid-offset that you configured.
  • config—Indicates that the I-SID value is statically configured.
  • notAvailable—Indicates that no I-SID value is available because EAP with FlexUNI is not used.
NonEapAuthType
Indicates the authentication type of the Non-EAP client:
  • radius - received from RADIUS server.
  • lldp - received from Link Layer Discovery Protocol (LLDP).
AclId
Indicates the dynamic Access Control List (ACL) on the specific port.
AceIdList
Indicates the list of dynamic Access Control Entries (ACE) on the specific port.
DynamicSettings
Displays the dynamic settings received from the Remote Authentication Dial-In User Service (RADIUS) server and successfully applied on the port or VLAN.
MhsaDynamic
Specifies whether or not the switch receives the MHSA VSA settings from RADIUS.
